Vyhledat témata bez odpovědí | Zobrazit aktivní témata Právě je 27.10.26, 14:39
 Felicia přístrojová deska podsvícení
Příspěvek Felicia přístrojová deska podsvícení
CZ
Každý ví že Felicia deska podsvícení je příliš tmavý. Takže bych chtěl vědět co snadná výměna jste místo těch 2W žárovky (4 kusy), aby bylo jasnější. Přiložte prosím veškeré detailní foto přístrojové desky pokud můžete.
ENG
Everybody knows that Felicia dashboard backlight is too dim. So I would like to know what simple replacement you did instead of those 2W bulbs (4 pieces) to make it brighter. Please attach any detail photo of your dashboard if you can.
1.3 Felicia LX karburátor
16.4.13, 06:28
Příspěvek Re: Felicia přístrojová deska podsvícení
Interesting idea, but there is a problem - plastic parts will be destroy in case of use powerfull bulbs.
How old are your present bulbs in this? I think change it for new original pieces will help, dashboard in Felicia shine very good if it´s OK :)
16.4.13, 17:11
bulbs are too old, dust in the dashboard, voltage in dashboard is too low (bad contacts, oxidation), or you can replace bulbs with LED. If you use more powerfull bulbs, the plastic parts of dashboard will melt by heat. It's also handy, if you replace the bulbs with LED to add a potentiometer, to allow brightness regulation (can be too bright at night)
how to replace bulbs (CZ) http://felicia.manas.name/vymena-zarove ... ova-deska/
16.4.13, 18:51
My bulbs are new, just replaced them because some were old and dark. I cleaned perfectly everything inside (light guides, printed plastic masks, etc.). Battery and alternator are ok, voltage is normal. Where I live, there are 5 Felicia that have exactly the same problem. I know that bigger bulbs will melt the plastic of light guides, not to mention they don't even fit inside (see drawing). LEDs don't have enough light intensity (I need 40 lumen/LED) and their light pattern is too directional (I need a 170 deg. spread). Trust me, I am out of solutions. I wish I say "this dashboard is too bright"...
16.4.13, 22:07
http://www.mall.cz/vykonne-celovky/ zkus tot totok velice dobře ti to přístrojovku osvítí :D
22.4.13, 20:57
[ Time : 1.211s | 10 Queries | GZIP : Off ]
