Vyhledat témata bez odpovědí | Zobrazit aktivní témata Právě je 25.10.26, 21:39
Odpovědět na téma  [ Příspěvků: 24 ]  Přejít na stránku Předchozí  1, 2
 tachometer felicia - ručička začala skackať
Vývojář
Příspěvek Re: tachometer felicia - ručička začala skackať
New type is modified because old type had a problem with plastic cog-wheel. This part tore out from cable in some cases. I think you cann´t use the new type. But I´m not sure :!:
edit:
This is the same topic viewtopic.php?f=12&t=32737&p=576427&hilit=n%C3%A1hon+tachometru#p576427
Ex auta:
Peugeot 106 1.1 '02
Fáčko 136L '89 Bělouš
Š Felda 1.3 MPI Combi '97
Fáčko 1.3 Lxi '93
Š 120 LS '78 Beruška
11.8.14, 08:08
Thank you for explanation. I found a photo that confirms what you said.
I didn't know the cog wheel cracked on many cars.
1.3 Felicia LX karburátor
11.8.14, 09:07
Vývojář
I think you should replace only cable, the current part with plastic cog wheel can be used if there aren´t any damages.
Ex auta:
Peugeot 106 1.1 '02
Fáčko 1.3 Lxi '93
11.8.14, 09:36
I oiled the cable and made sure it is not bent.
The speedometer needle is still shaking hard between 0-40 km/h :(
I don't see other solution but buying a new cable.
But I am not too optimistic that the needle vibration will stop...
Jsem olejem kabel a ujistili se že není ohýbat.Rychloměr Jehla je stále vibruje těžké mezi 0-40 km / h :( Nevidím jiné řešení ale kupovat nový kabel. Ale já nejsem příliš optimistický že jehla vibrace se zastaví ...
11.8.14, 14:04
Vývojář
The quality of the parts from aftermarket is low, unfortunately. I think that the replacement will be successful solution of your trable. Does your friend /anybody/ have the same type of car? If yes then you can use his part /cable/ for test.... Remember your test with electric drill - it was OK, no vibrations of the needle of speedometer. The problem must be in this cable....
Ex auta:
Peugeot 106 1.1 '02
Fáčko 1.3 Lxi '93
11.8.14, 22:17
It is a good idea to borrow a speedometer cable from a friend. He will return from holidays in 3 days. But I could try something else till he comes back. Here is my plan:
I will raise the car on jack stands (see photo) and I will open the bonnet to have access to speedometer cable.
A friend will stay in the car and he will start the engine, then shift in 2nd gear and accelerate at 30 km/h.
I will move the cable and my friend will tell me if there is a position where the speedometer needle stops vibrating.
I think this test will show exactly if the problem is the cable position or the cable itself.
What do you think?
12.8.14, 03:03
Vývojář
It´s good idea. Try it.
Ex auta:
Peugeot 106 1.1 '02
Fáčko 1.3 Lxi '93
12.8.14, 06:42
Vyřešil jsem problém. V mém případě jsem našel dvě řešení:
- viz obrázek níže, to je samozřejmý
- zatlačte celou délku kabelu a upevněte ji jak je znázorněno na následujícím obrázku
17.8.14, 11:52
Vývojář
Congratulations. Felicia forever :wink:
Ex auta:
Peugeot 106 1.1 '02
Fáčko 1.3 Lxi '93
17.8.14, 13:19
[ Time : 0.458s | 11 Queries | GZIP : Off ]
